Last Updated On: June 11, 2019
What is Audio Noise Reduction?
Regardless the microphone quality, there is a high chance that your recordings will have some background noise. So, ActivePresenter 7 provides a new feature called Audio Noise Reduction. Generally speaking, it’s a process of removing noise from an audio track. Noise reduction can reduce constant background noise such as tape hiss, electric fans or hums.
Using Audio Noise Reduction
In general, the procedure to use the Audio Noise Reduction feature is to get Noise Profile, then reduce the noise.
Step 1: Get Noise Profile.
  1. Specify the range that contains background noise only.
Note: If the selected range is too short, the app cannot get the Noise Profile. You must select a minimum 2048 samples, or about 0.05 seconds at 44100 Hz sample rate.
  1. Click the arrow button on the Audio Noise Reduction button (1), then select Get Noise Profile.
Specify an audio range containing noise only
After that, Noise Profile will be stored in the program. When you close the program or replace it with another Noise Profile, it will be lost.
You can reduce noise for the whole audio track or just a part of it. In both cases, you have to specify the audio range containing noise only first. Then, select Get Noise Profile by clicking the arrow button on the Audio Noise Reduction button so that ActivePresenter can identify the noise in the audio. To reduce noise for the whole audio track, you need to do one more thing before moving to the step 2: double click anywhere on the time axis to choose the entire track instead of a range.
Step 2: Reduce noise.
After getting Noise Profile, you can apply Noise Reduction to a certain range in the audio track or to the entire file.
  1. Select the range or the audio tracks you want to apply Noise Reduction.
  2. Click the Audio Noise Reduction button timeline_noisereduction. Then, the Noise Reduction dialog will appear:
  • Noise reduction (dB): Control the amount of volume reduction (0 – 48) applied to the identified noise.
Higher values reduce a higher amount of volume reduction, making the noise quieter but can distort the audio track. Keep this control as low as possible.
  • Sensitivity: Control how much of the audio will be considered noise.
Greater sensitivity will remove more noise but can damage the track. Keep this control as low as possible.
  • Frequency smoothing (bands): Spread the noise reduction into the specified number of neighboring bands.
Smoothing can make the desired audio less clear, so set the value to 0 if your desired signal is strong and the noise is low.
  1. Click OK to apply the effect and close the dialog.
If the Noise Reduction effect doesn’t work as well as you expected, you can press CTRL+Z and try Noise Reduction again with different settings. Note that you don’t have to get a new Noise Profile if you think the existing is good enough.
TipIf there are many different kinds of noise in different parts of the audio track, you should repeat the process several times. For example, after reducing noise for an audio track, there might be several parts that noise is not completely eliminated. So, you should get the noise profile for the first part, then reduce the noise for it. Continue picking the next part and reduce the noise until you satisfy with it.
Sometimes, the audio track doesn’t have any part that contains only background noise and you cannot get the noise sample. In such case, you can create a recording made in identical conditions containing silence only, then use a noise sample from that to reduce noise from the recording you want.
That’s all. Use the Noise Reduction feature in ActivePresenter 7 to enhance the audio quality used in your projects. Remember that there are many useful tutorials about editing audio tracks on the tutorial page, feel free to check it out.
