ActivePresenter has long been known as a powerful all-in-one eLearning software that combines screen recording, video editing, and interactive course design. With the release of ActivePresenter 10, one of the biggest highlights is its completely redesigned interface: modern, intuitive, and more convenient than ever. The new layout not only looks better but also improves usability, helping users work faster and boost productivity.
From the Start Page to the Workspace, every detail of the ActivePresenter 10 interface has been refreshed to deliver a smoother and more user-friendly experience. Whether you are a teacher, trainer, or content creator, you’ll find it easier to harness the full power of this software.
Let’s take a closer look at what makes the ActivePresenter 10 interface stand out!
A Completely Redesigned Interface
The first noticeable change in ActivePresenter 10 is its revamped user interface. The new icon set is sharper, and features are arranged in a more logical layout. This allows for quicker navigation, reduces learning curves, and makes long working sessions more enjoyable.
As a result, creating responsive courses, software simulations, screen recording tutorials, or interactive videos becomes smoother and more time-efficient than ever before.
Start Page – The Beginning of Your Creative Journey
When launching ActivePresenter 10, you are welcomed with a fresh and intuitive Start Page, designed for easy project creation. The Start Page is divided into two main sections: the Center Area and the Left Panel.
Center Area
The ActivePresenter Templates section immediately draws attention with a collection of professionally designed themes. By simply choosing a suitable template, you can quickly start building a course without creating everything from scratch. This is a huge time-saver for teachers and eLearning designers.
👉 Benefit: Save time and start your projects faster!
The Quick Start section provides multiple options to begin new projects, including:
- Blank Project: Create a brand-new course from scratch.
- Record Interactive Simulation: Capture interactive simulations of software operations.
- Record Screen As Video: Record your screen activities in video format.
- Import PowerPoint: Convert existing PowerPoint slides into interactive eLearning content.
- Responsive Project: Build responsive courses that display perfectly across all devices.
Left Panel
The Left Panel works as a secondary navigation hub:
- Top Section: Displays the ActivePresenter 10 logo, “What’s New” button, sample projects, and user manual.
- Recent: Lists recently opened courses for quick access.
- Bottom Section: Provides shortcuts to essential resources like Preferences, Product Information, Check for Updates, User Community, and ActivePresenter’s YouTube tutorial channel.
Workspace – Where Ideas Come to Life
Compared to version 9, the ActivePresenter 10 Workspace has been further streamlined and made more intuitive. Different types of slides (slide master, feedback master, slide pool) are grouped more clearly, enabling smoother content design.
The Workspace is divided into three main parts: Tabbed Toolbar, Document Window, and Status Bar.
Tabbed Toolbar
The Tabbed Toolbar is located at the top of the application window, serving as the central hub for all editing and design tools. It consists of:
- Quick Access Toolbar: Contains basic commands like New Project, Open/Save, Undo, and Redo.
- Document Tab: Display open projects for easy switching.
- Core Tabs: Grouped logically by function for faster navigation. Tooltips with explanations and shortcuts appear when hovering over any command.
On the far left, the File button provides access to file management, settings, and recent projects. The toolbar can also be customized or hidden as needed.
Document Window
The Document Window allows you to work on multiple projects simultaneously, displayed as tabs. It includes:
- Slide Pane: Shows thumbnails of all slides. You can switch to Master Slides, Feedback Masters, or Slide Pools, and change slide display modes (Column, Grid, or Title).
- Canvas: The main working area where slide content is displayed and edited.
- Timeline Pane: Displays all slide objects along a timeline. You can fine-tune object durations, edit audio/video, record narration, and add markers.
- Properties Pane: Customize appearance and behavior of selected objects.
- Resources Pane: Manage all project resources in one place.
- Selection Pane: List and organize slide objects; lock, hide, or reorder them easily.
- Object States Pane: Define multiple states for an object to respond to learner interactions.
- Object Templates Pane: Save and reuse object templates across different projects.
You can fully customize the workspace layout by hiding, resizing, or rearranging panes. To restore the default layout, simply go to View > Reset Pane Layout.
Status Bar
Located at the bottom of the window, the Status Bar displays current project information and provides:
- Quick HTML5 Preview of your course.
- Canvas zoom controls for scaling content.
- Spell Check toggle: Misspelled words are underlined in red and can be corrected with right-click.
UI Themes – Light & Dark Modes
Just like previous versions, ActivePresenter 10 retains the familiar Light and Dark UI themes, giving users flexibility and comfort. This personalization enhances the editing experience and helps reduce eye strain during long working sessions.
When launching ActivePresenter for the first time, you can select your preferred theme. The chosen theme will automatically become the default for future launches.
At any time, you can switch between Light and Dark modes by navigating to: View > UI Theme > Light/Dark.
Conclusion
With the new ActivePresenter 10 user interface, you’re not just getting a more powerful eLearning authoring tool, you’re also enjoying a modern, intuitive, and customizable workspace. From the time-saving Start Page to the streamlined Workspace and Light/Dark UI themes, everything is designed to maximize productivity and comfort.
If you’re looking for a professional, versatile, and user-friendly eLearning software for creating interactive courses, video tutorials, or online training, ActivePresenter 10 is the perfect choice.
These updates to the interface go hand in hand with the many new features introduced in ActivePresenter 10.
👉 Download ActivePresenter 10 today and start creating engaging eLearning content with ease!
